Toilet Drain Location
Discussion in 'Toilet Forum discussions' started by Wally3433, Apr 9, 2010.
  1. Wally3433
    Wally3433 New Member
    Mar 20, 2010
    Illinois
    I am remodeling my bathroom. We are going to re-install our existing toilet, but down the road we would like to upgrade to a new one.
    Is there a standard offset distance from the center of the toilet drain to the edge of the finished wall - or does this vary widely from toilet to toilet?
    Most of the larger toilets I see appear to have the same distance from drain to wall, but wanted to confirm this.
    I am trying to determine if I need to adjust the distance now as opposed later.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Yes. The standard rough-in space is 12". Every toilet manufacturer make them that size. You can get a 10" or a 14" toilet, there are less choices in models in those two sizes. The distance is measured from the center of the drain to the finished wall. Note that many 12" toilets can be installed closer to to the wall, but stay with a 12" and you're good to go.
  4. Wally3433
    Mar 20, 2010
    Illinois
    This is good news to me. Thanks. Now, I hope my existing distance is 12"
  5. Gary Swart
    Sep 1, 2004
    Yakima WA
    If it is little shy, come on back with the exact measurement. Terry can tell you to a fraction of an inch the actual space you need, especially for Toto toilets. It seems rough-in sizes never exceed their listed space requirement, but often you can get by with up to 1/2" or so less. It's not an exact science.
Similar Threads: Toilet Drain
Toilet Forum discussions Replace rear drain with a ground drain toilet Dec 12, 2016
Toilet Forum discussions 180 degree turn on 3" toilet drain Sep 12, 2016
Toilet Forum discussions Is it the toilet or the drain/vent causing the constant clogging? Sep 11, 2016
Toilet Forum discussions Lead toilet drain worth replacing? Aug 27, 2016
Toilet Forum discussions Weird toilet sewer drain help??? Jul 26, 2016
