Toilet always clogs, no matter what
Discussion in 'Toilet Forum discussions' started by law, Jun 5, 2005.
  1. law
    law New Member
    Jun 5, 2005
    So we've recently moved into this new apartment, everything about the place seems fine, except the toilet always clogs! My girlfriend and I are hardly what you'd call "power sh*tters", but the tiniest bit of toilet paper clogs the darned thing and is cause for a good 10-15 minutes of plunging (which isn't helped by the strange channel-type cutout at the bottom of the toilet, which prevents the plunger from getting a good seal) This happens literally EVERY TIME I "use" the toilet, and is wicked annoying. The landlord says that he's had no complaints from the other tenants (we're on the ground floor of a good ol' Massachusetts triple-decker), so we figure the extra "height" that the other families have is helping their toilets to flush properly. Do you folks have any idea what could be causing our chronic clogging, and do you have any ideas as to how to fix it?
    Many MANY thanks,
    --Lee
  2. jimbo
    jimbo Plumber
    Chelsea? Dorchester? Revere? Just reminiscing. ( Grew up in MA)
    There is a problem here and your landlord may need some gentle prodding because it is his problem. For a test, take a large bucket(at least 2 gallons) of water and pour it into the toilet. It should cause a nice flush. If it is sluggish, there is a problem somewhere. The scary part is if the problem is out in the main then you could have a situation where the drainage from the upper floors finds the only path gravity allows is out through your tub or toilet.
  4. hj
    toilet
    If a toilet is vented properly, which we have to assume all of them are, then the extra height does not help them flush. Your problem is probably inside your toilet and needs a snake to pull it out, (not a plunger to push it in further), or removal to dump whatever is in it out.
  5. captwally
    captwally New Member
    Apr 30, 2005
    Apartment Complex Maintenance, Professional Chef
    Florida
    Assuming that all vents and drains have been snaked to properly ensure flow, my guess is that you are the victim of one of the stupidest things the government has done this century, mandating low flow toilets. It ranks right up there with prohibition, and we all know how long that lasted. What's the point of having a toilet that uses half the water to flush of older style toilets if you have to flush it three times? It's not like the water you are using is going out to space.
    As an apartment complex owner and Maintenance Supervisor, I have had nothing but problems with these "low flow" toilets. After all, I am not going to plunge someone else's ***p out of their toilet. That's their job, just like replacing a lightbulb. See if you can convince your Apartment management to look into the newer American Standard toilets. They are "low Flow," but can flush just about anything, from routine biological functions to kids' toys to up to 24 golf balls. Not that you would ever find yourself flushing 24 golf balls down the can....
    I am replacing all my tenants' toilets with these because It will reduce my problems, though I am replacing them on an "as need" basis. Besides, I want my tenants to be happy!
    Good Luck
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    previous tennant
    if this has been this way from the day you
    moved in, their is also a good cance the
    previous tennant might have dropped something like a colmb
    or pencil down the toilet before they moved out.
    this should be looked at by the
    landlord. either snaked out or changed out
Similar Threads: Toilet always
Toilet Forum discussions Does Toto make a Toilet with Washlet or is the Washlet always an add-on? Dec 2, 2016
Toilet Forum discussions Is the toilet horn always even with the bottom edge of toilet? Jan 14, 2016
Toilet Forum discussions Toto (AquiaIII) Toilet - Screw at bottom right always coming loose - HELP ! Feb 23, 2011
Toilet Forum discussions How is the toilet made the difference between 1.28 and 1.60 GPF toilet? Saturday at 9:18 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
