tightening copper fittings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tom gelzleichter, Jun 10, 2009.
  1. tom gelzleichter
    tom gelzleichter New Member
    Jun 10, 2009
    I'm getting ready to install a new shower flow valve assembly. I'm plumbing into existing hot/cold by sweating fittings; however I have to use male fittings to first plumb into the control valve assembly. The way I see it i'll have to install everything and sweat the inlet lines before I can pressure test the whole system. But if there is a leak around the male threads it will be too late to tighten as the rest of the fittings are already set. How do you pros deal with this issue? Am i missing something simple?
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Rectorseal and teflon tape
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Usually we buy valves that we solder directly to.
    However when presented with the big box store version many of us wrap teflon tape on the male threads then apply teflon paste over the tape and tighten.
  5. jadnashua
    Some valves allow you to insert the pipe into it and solder it, or, screw on an adapter. If the valve has male threads, see if your pipe will fit inside, then just solder it.
  6. hj
    valve
    He specified that he has to use male adapters which means the valve has FIP connections so the copper will not fasten directly into it. I prefer to solder the male adapters into the valve so there is no possibility of a leak for any reason.
Similar Threads: tightening copper
Plumbing Forum, Professional & DIY Advice American Standard 2 knob faucet cartridge - tightening - valve open or closed? Jul 16, 2016
Plumbing Forum, Professional & DIY Advice Any tips/tricks on tightening flange bolts? Mar 2, 2014
Plumbing Forum, Professional & DIY Advice Tightening dwv test plugs Apr 7, 2013
Plumbing Forum, Professional & DIY Advice about tightening packing nut on old main house shutoff valve Jan 26, 2013
Plumbing Forum, Professional & DIY Advice Tightening loose handle on Moen 6610 bath faucet Jun 7, 2012
