Johnny-Canuck
As part of a different issue, I totally drained my hot water tank from it's drain tap. (I just ran a hose from its drain to a tub on the floor above). After I did this, all the taps in the house worked normally, except for a basement workroom work tub that was relatively close to the hot water tank.
From the water tank area, the 2 water supply pipes for the tap run through the basement ceiling stud area for about 4', make a 90 degree turn and run for about another 2', then finally make a 90 degree drop down to the problem tap.
I don't have any spots in these 2 lines that I can see I might be able to drain them.
I've tried closing the main house supply, opening all the taps in the house & flushing the toilets till everything stopped. Then opening the supply at the main again and then closing all the taps from the basement then up to the 1st & finally 2nd floor. I expected this might correct the problem but it didn't.
Any suggestions?
If I shutoff the supply at the MAIN and I remove the 2 valve stems at the tap is there something I can do from this side of the copper pipes? Try to force water into them? Try to use a vacuum to suck something out of them (air? water?). Would this do anything?
Any suggestions?
