Thin Wall to Schedule 40 fitting
A12548
Florida
Expanding a zone, and unfortunately, it needs to come off a thin wall 1" pipe. Replacing the thin wall line completely is currently not an option. The 1" thin wall can barely fit a 1/4" inside a Schedule 40 coupling. Is there an adapter coupling or any other solution to join the two?
I presume this is PVC. I am not familiar with the pipe you are talking about.
A schedule 40 pipe does not fit far into a coupling either, until you use primer and glue.
I suggest that you measure the OD of the pipe that you are trying to connect to. If it is 1.315 OD, I would think you could use schedule 40 couplings.
WorthFlorida
Solutions
Orlando, Florida
HJ is correct. A picture would help but any pvc pipe regardless of schedule size will fit. What I think your reference of thin wall pipe is pvc with a pressure rating of 160 psi. You’ll see it printed on the pipe. Next up is schedule 20, then 40. On the thin wall pipe smooth down the end with a scrubbing pad. There probably is a burr on the end of the pipe snagging the fitting. Check inside the fitting that it is molded correctly. Once in a while you’ll get a bad one. You can put a little water on the fitting to act like a lubricant for a dry fit. Once you put glue on it it should slip on pretty easy. Use a little hammer or rubber mallet to tap the fitting on the pipe.
Dj2
California
Use a mallet after you prime it and put glue. Bang on a piece of 2x4 not to damage the fitting.
I used to use a sledge hammer to connect sections of ABS for a main line, when I was young.
