These are not vents
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jar546, Feb 20, 2008.
  1. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    Another wonderful plumber. IRC applies.
    [​IMG]
  2. MG
    MG New Member
    Jun 29, 2005
    Illinois - Near St. Louis
    hmm - wouldn't the change just be to ditch the sanitary tee's to combos and fix that S trap?
  4. jar546
    Feb 20, 2008
    USA
    Do ya tink it wood be eezyr to doit rite da furst time?
  5. hj
    code
    Maybe it is to the IRC code.
  6. Spaceman Spiff
    Spaceman Spiff Architect
    Architect
    Salt Lake City, Utah
    2006 IRC Table P3005.1 prohibits san-tees in vertical to horizontal and horizontal to horizontal.
    §P3201.5.3 specifically prohibits "S" traps.
    They forgot to read chapter 31 "Vents"
    Beyond that it looks like there's a belly where the plastic hanger is...
  7. fidodie
    fidodie New Member
    Jan 22, 2008
    computers
    new jersey
    is that yellow line NG or LP ? does it need to have a pitch to it?
  8. Cass
    Cass Plumber
    Nov 12, 2005
    No plumber did that.
    I can see the home owner standing in the isle of Low*s saying " why do I need to spend extra money on these Ys and 45s. Ill just use these Ts and save some $$$$. it will do the same thing.
  9. jar546
    Feb 20, 2008
    USA
    Unfortunately this is new construction and it was performed by a "professional" plumber AND approved by the code inspector under the IRC.
    Now it needs to be changed and done right by a real plumber
  10. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    As I understand it, IRC does not require vents for closets. however, that 2" trap is not a closet. Seems as if it would have to require a vent somewhere . . .
    Dayum, but I hope we never see IRC here. I thought trailers were bad enough.
  11. fidodie
    fidodie New Member
    Jan 22, 2008
    computers
    new jersey
    since it is such a mess, that 2" trap is probably a washing machine - making it even more of a violation - may as well pile it on!
  12. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    That is how that pipe is hung. Could be ward flex or trac pipe or one of the many other brands. I think most inspectors like it a bit tighter. It is ment to be loose so if a nail hits it it will move away.
    Just incase you or anybody else didn't know.
  13. Cass
    Cass Plumber
    Nov 12, 2005
    It doesn't matter if the guy was licensed and it was inspected by 100 inspectors...the guy wasn't a plumber.
    The inspectors were paid off or never realy looked at it.
  14. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    I know we live in a government controlled, code crazy world, but I've seen a lot of sanitary tees on their backs in cast and pvc in all kinds of situations and they were never a problem. When I first started out and didn't know any better and we had no inspections and codes to deal with I did it when in a pinch, not saying at all it is right, just saying if I had a house with it plumbed like that and had to pay a plumber, I wouldn't go cutting them out just to make them compliant with the modern code. I would worry about proper venting and things that caused me issues, but not a tee on it's back.
  15. fidodie
    fidodie New Member
    Jan 22, 2008
    computers
    new jersey
    Thnx! i'm moving an NG dryer this spring....can look it up by name now.
  16. jar546
    Feb 20, 2008
    USA
    Ignorance can be bliss. Ignorance cannot, however, be an excuse. They don't manufacture T's to be on their back, that is why they have Y's. So you really need to know what to use, when and why. It is the mark of a professional.
  17. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    But this is a DIY forum! ;) Doing It Your way
  18. construct30
    Jun 16, 2007
    NorthWest PA
    Pros do it correct always? Right. New jobs should always be as close to perfect as you can get them, text book in fact and most can, but a repair or remodel sometimes can't be without changing all the old junk, which when possible should be done, but people don't want an entire replumb to fix a small leak nor do they want to replumb the entire house to fix a few tee's on their back if its worked for 75 years that way.
    As an inspector I hope you fail every job done that way, how did it get passed in the first place? I hope it doesn't cost the homeowner.
  19. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    One of the primary reasons that tees are not supposed to be on their backs is because of drain cleaning. It hasn't always been done with snakes - there are also ridgid flat tapes that don't bend very well. It doesn't matter whether it's cast iron or plastic, it isn't hard to blow the back side of one of those tees out.
    And a modern root cutter would make quick work of the backside of a tee.
    If the code says that an upper vent terminal is a cleanout, and you drop a snake or tape straight down, there's a good chance you'll destroy the tee.
    Here, inspectors have allowed us to have regular 90* elbows at the base of a stack rather than longsweeps. I really don't see anything wrong with that now that we're using plastic. Surely, you wouldn't want a vent 90* in a place like that. But it's smooth enough and round enough to either get a snake through it or for sewage to make the turn.
    A tee is a slightly different animal - not only is there NO TURN, but there's no directional movement. Things drop straight to the bottom. (back)
    Chances are, you could plumb a house with tees on their backs and you'll never have a problem with them. Chances are you don't even need a bathroom if you have woods near your house. It's so easy to simply do it right in the first place. It's so much better when things not only work, but work well.
  20. construct30
    Jun 16, 2007
    NorthWest PA
    Gotta love the woods. I prefer a good old out house.
    That's why we have and need inspectors, to keep the pros honest and the DIYer's on the right track. It can even be helpful when trying to convince some home owners to pay for doing it correct.
  21. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Why would a gas pipe need pitch? in case you want to drain it? :D
Similar Threads: vents
Plumbing Forum, Professional & DIY Advice New Radiator Air vents Still Hissing Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Raising the roof.... Eh herm, ceiling. Advice moving plumbing and vents. Dec 20, 2016
Plumbing Forum, Professional & DIY Advice Odd occasional smell coming from vents Nov 30, 2016
Plumbing Forum, Professional & DIY Advice Do drains leading into lift pump need vents and traps Jul 28, 2016
Plumbing Forum, Professional & DIY Advice Installed Vents. Please Doublecheck My Work. Thanks! May 3, 2016
