Tapping noise from hydronic heating in apt.
Discussion in 'HVAC Heating & Cooling' started by robertc, Dec 12, 2007.
  1. robertc
    robertc New Member
    Dec 12, 2007
    Hi, I know very little about plumbing.
    I live in an apt building with a hydronic heating system. There is a clicking noise from the pipes getting hotter. Sometimes the clicking is very rapid, almost like a machine gun (but not that loud), which will happen once every hour or so; other times, there is a single "click" and then five seconds of silence and then another single click. This happens very often.
    Do you know why the two different noises would happen?
    Is it possible for the clicking noise to be caused by trapped air, or anything else besides the pipes expanding?
    Thanks.
  2. jadnashua
    As the pipes expand and contract, if they're rubbing on something, they'll click. It will likely be quicker when the heat turns on because the temperature of the incoming water from the boiler is quite hot; when the circulator turns off, it just stops moving the water, and then, instead of introducing really hot water into cold pipes, it just sits there and slowly cools off, so it doesn't change temperature very fast, thus the slower clicks.
Similar Threads: Tapping noise
HVAC Heating & Cooling Start up noise Heat Pump Aug 21, 2016
HVAC Heating & Cooling Condenser fan noise and then blade breaks. Advice Please. Sep 28, 2013
HVAC Heating & Cooling Heat Pump inside unite making clicking noise. Apr 25, 2012
HVAC Heating & Cooling Attenuating HW Recirc Pump Noise Mar 3, 2012
HVAC Heating & Cooling Humidifer wiring causes sheet metal click noise - is it solinoid? Mar 4, 2010
