Taking Water Supply to new heights?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by prashster, Feb 13, 2006.
  1. prashster
    prashster New Member
    Dec 7, 2005
    I'm planning a bathroom.
    Is there a code restriction on how high/low in a wall you can run the water supply lines horizontally? I want to run them at 12" above the floor through the 2x4 studs framing the wall. The electrical wires run at 24" above the ground.
    For that matter, is there a restriction on the electrical wiring heights?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    You can run them where ever your heart desires, just be sure it is not in an area that will freeze. Freezing will not affect the wiring unless it gets at or near absolute 0. :)
Similar Threads: Taking Water
Plumbing Forum, Professional & DIY Advice Bubbles in all the toilets when water drains from washer or someone is taking a showe Jan 19, 2013
Plumbing Forum, Professional & DIY Advice Revised post re: hot water taking tolong to get to faucet Feb 24, 2010
Plumbing Forum, Professional & DIY Advice Water Heater taking 5 minutes to heat up Jan 12, 2009
Plumbing Forum, Professional & DIY Advice Low water pressure and water taking long time to heat Nov 15, 2008
Plumbing Forum, Professional & DIY Advice Ejector pump taking on water from under slab? Sep 25, 2006
