Takagi Jr Radiant Heat Issue
Discussion in 'Tankless Water Heater Forum' started by kjensen, Dec 16, 2010.
  1. kjensen
    kjensen New Member
    Dec 16, 2010
    Wisconsin
    Help! My one-year old Takagi Jr used in a radiant heat installation has died. It worked fine last winter and seemed to be Ok this year until we got some below 0 weather. If I turn off elec., wait a minute, then restart, it will fire and everything seems normal. It will run about 1-2 minutes, then quits and shows error codes. Error codes seem to alternate between light flashing 3 times and light flashing 4 times. I've cleaned the flame sensor as mentioned in another post (and damaged the fiber gasket but I think i pieced it back together OK). The only difference between this year and last is that I added a direct vent. I bypassed the direct vent (opened the cover on the unit) and then the unit ran until the thermostat shut it off but now it will not run again. I should also mention that the exhaust vent is dirty with what looks like soot. Hope this is not too confusing and someone has some ideas - No one in my area seems to work on these units.
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Check for obstructions (including frost) on the air-intake venting for starters.
    Is this a propane or gas unit (and is it on the correct fuel?).
    Call the Takagi technical help line- they have a reputation for being able to talk most anyone through a debugging cycle.
  4. kjensen
    kjensen New Member
    Dec 16, 2010
    Wisconsin
    Thanks for your ideas - Both intake and exhaust are clear. This unit runs on LP and the dip switch is correctly set for LP. I will try Takagi tech support.
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    IIRC, the dip switch only indicates to the control board which coefficients to use in order to have the same control board for both the -LP and -NG models. If the model number ends in -NG you have it running the wrong fuel (it'll usually run, but with the wrong mixture, and neither it's longevity nor it's efficiency will be near expectations.)
    In cold weather frost formation on air intakes can make burners run fuel-rich, and can show up as sooty deposits before it out & out won't run.
    According to the manual (see p.17) a 3-blink error code can mean issues detected with any of :
    Hi-limit
    Igniter
    Flame Sensor
    Main Gas Valve
    Proportional Gas Valve
    Abnormal Burning
    A 4-blink can mean issues with either:
    Fan
    Pressure switch
  6. Tecno
    Tecno New Member
    Dec 24, 2010
    maine
    Do you have a Backflow preventer installed in the Exhaust pipe?? if so make sure that it can move freely.I have one on my unit and i found that it had stuck shut my bad should have done the yearly check on the unit I cleaned out the pipe and made sure that it moved freely and it fixed the problem.
Similar Threads: Takagi Radiant
Tankless Water Heater Forum Problem with Takagi & Radiant Heat &Domestic Hot Water Jun 17, 2008
Tankless Water Heater Forum Strange problem with Takagi T-K3-OS Nov 11, 2015
Tankless Water Heater Forum Takagi t-k1s won't ignite when cold . . Nov 10, 2015
Tankless Water Heater Forum Takagi T-K1S Just Quit, Now What?? Oct 20, 2015
Tankless Water Heater Forum Takagi TK2 vibration/unstable flame May 4, 2015
