taco 557 valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pauloden, Mar 5, 2011.
  1. pauloden
    pauloden New Member
    Mar 5, 2011
    Vermont
    I have a taco 557-G2 valve to allow water to flow through my climatemaster heat pump.
    After about three years the valve allows some water to leak by all the time. This is the second valve to do this. After taking the valve apart I can't find anything wrong. Its clean and the seats seem to be in good condition and the spring is very strong. Water pressure is 50 psi.
    Any sugestions ? Are there better valves out there that will do the same job ?
Similar Threads: taco valve
Plumbing Forum, Professional & DIY Advice Taco Zone Valve Question Aug 21, 2013
Plumbing Forum, Professional & DIY Advice Taco 5000 mixing valve help Nov 16, 2010
Plumbing Forum, Professional & DIY Advice Soldering Taco Flo-Chek - Should Valve be Removed Nov 11, 2005
Plumbing Forum, Professional & DIY Advice Taco 705-2 variable speed injection pump with ECM energy efficient pump? Apr 17, 2015
Plumbing Forum, Professional & DIY Advice No hot water to shower, TACO circulater possible problem Apr 16, 2014
