System Pump Suddenly Louder.
Discussion in 'Boiler Forum' started by mage182, Apr 4, 2013.
  1. mage182
    mage182 Member
    Feb 17, 2011
    New York
    I have a Burnham Alpine 150 with a Taco 0014-F1 as the system pump on the primary loop as spec'd in the install manual. The pump is approximately 2 years old. In the past week or so the pump has become louder. It sounds like a buzzing that is consistent and is louder than all 4 Taco 007 zone pumps that I have combined when running.
    I took the pump out and disassembled it thinking maybe something was stuck in it or that the cartridge in it had gone bad already but found nothing. No foreign matter or play in the impeller shaft.
    Any other ideas on what would be causing the problem? I don't want to buy a $140 replacement cartridge if it isn't the answer.
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    It could be the capacitor.
    It might be worth testing.
    It should be 14uf 250VAC.
    Good Luck.
  4. mage182
    mage182 Member
    Feb 17, 2011
    New York
    I took the pump apart again. There was some scuzz clogging the fins of the impeller on one side causing the whole thing to be unbalanced when rotating. I cleaned it up and put it all back together. Now it runs pretty much silently.
  5. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Nice work.
    It is great that you got it working properly.
    Enjoy.
Similar Threads: System Pump
Boiler Forum Balancing pumped hot water system May 3, 2016
Boiler Forum adding a circulator pump to a single zone system Dec 14, 2011
Boiler Forum Circulating Pump: Reuse No-Loop Pump in Looped System? Jan 1, 2011
Boiler Forum New boiler - water pumped backwards through old system Dec 31, 2009
Boiler Forum Need help understanding and adjusting temp on boiler system pics included Feb 14, 2017
