Ricketts
Hi everyone;
I can't seem to get the search function to work tonight for some reason. My 1" swing check valve on the inlet side of my jet pump is slowly beginning to let water bleed back.
I just replaced this 1 year ago when I replaced the pump, and it worked great up to about a month ago. Are these repairable? I do not know what the model or brand is - the only markings on the valve are 200WOG. There is a small hex head bolt, I am assuming for the hinge, and a large nut on top that looks removable. If it is a simple process to drop the pressure, pull off the cover and clean it/check for wear, I will tackle it before ripping everything apart to replace. It wasn't cheap, so I don't want to have to replace it once a year.
Are there any websites that have any info on repair/issues/anything else to look for on a swing check valve? Google has been no help, either. The only info I could really find online was a picture of a WATT CV Swing valve that looks identical to my valve.
Thanks for any information anyone can provide,
Rick
Rick
