Hello All,
I have an old cast iron pipe that is cracked. the crack leads up to a t-connection between the line coming out of my kitchen sink and a vertical vent pipe. Here is a picture:
As you can see the pipes sits a few inches away from one stud and about a foot from the other which is hidden from view by the wall. i have replaced most of the line coming from the main waste exit from the house to the point in the picture, so my intention is to continue replacing up to the cracked pipe. so here is my problem. I figure I will have to have to replace the entire t-joint(if not i'm luckier than i think), but that will mean cutting the vent pipe and the pipe from the sink. this doesn't seem like that big of a deal except, i am not sure how to support the vent pipe. i've read about riser clamps, but the clamp would have to be pretty long to make it to the "hidden" stud. or, if i can connect the t-joint to a pvc pipe without cutting into the pipe for the kitchen or the vent pipe. how do i support the weight of the vent pipe then as well? Can anyone give me some advise on how to continue?
Thanks in advance-
Todd
Thanks in advance-
Todd
