Sump pump wont start
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by pumpnewbie, Mar 15, 2013.
  1. pumpnewbie
    pumpnewbie New Member
    Mar 15, 2013
    British Columbia
    Yesterday I used my Liberty sump pump model s35 (spec sheet: http://www.paulsupply.com/files/LibertyS35.pdf )
    and it was working great. I had plugged it manually and forgot. About 4 hours later, I remembered that the pump was still powered on. The water had been completely drained and I think that the pump had been still running for about 3 hours or so thereafter with no water left. I noticed that the motor had stopped. I tried to re-plug it to restart but it wont start. I waited some hours because it has thermal protection but it still wont start.
    This morning I put the pump in a large bucket and filled it full with water since the pump has a Automatic Diaphragm Switch built into the pump. Nothing. The motor didn't even hum.
    Is it possible that the motor burnt out? Is there anything that I should try to get it going again? The power outlet is fine. I dont know the 1st thing about mechanics but hope the pump can work again. help :(
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    It's a submersible pump which should never be run without water flowing through it.
    Unless you are very lucky, it is ready for the scrap pile.
  4. pumpnewbie
    Mar 15, 2013
    British Columbia
    I thought the motor was dead but yesterday I plugged the sump pump into the outlet and I could hear the motor lightly humming (the pump was not in water I was trying it one last time before chucking it and then this low hum... ) so now I don't know whether it can work again or ... ?:confused:
Similar Threads: Sump pump
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Malfunctioning Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump loud bang Jan 16, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump pump discharge line Aug 10, 2016
Pumps and Tanks Well Forum & Blog. Water is life. I have 2 sump pumps - one pumps to another - need advice Feb 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Mystery (and question) Dec 29, 2015
