Sump pump cycles discharged water - Help!
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Wet Socks, Sep 30, 2011.
  1. Wet Socks
    Wet Socks New Member
    Sep 30, 2011
    Chicago
    My sister's sump pump (Zoeller in a basement sump) runs all the time and her basement has flooded more than once. When inspecting I unplugged the pump and the water stopped coming into the sump. It appears that whatever is being pumped out if being pumped back in. The discharge of the pump goes outside the building and is directed into footer tiles which leads to the city's storm sewer. When I disconnected the connection and placed the discharge into the yard, the problem was solved.
    However I now noticed that when it rains the downspouts for the roof are directed into the same footer tiles, which should go out to the street. Instead it goes back into the sump pump. She had a plumber out and he rodded out the storm sewer line to the street and put a camera into the footer tiles but didnt see any breaks in the pipe. How is it possible that water from the downspouts goes into the sump instead of the street?
    Any help is appreciated. We are stumped. Thanks
  2. Clydesdale
    Clydesdale New Member
    Dec 19, 2011
    Manitoba
    Do you have a check valve in the line to prevent back flow? You should if you don't.
Similar Threads: Sump pump
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Malfunctioning Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump loud bang Jan 16, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump pump discharge line Aug 10, 2016
Pumps and Tanks Well Forum & Blog. Water is life. I have 2 sump pumps - one pumps to another - need advice Feb 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Mystery (and question) Dec 29, 2015
