suction line air leak
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Bennet Young, Oct 2, 2006.
  1. Bennet Young
    Bennet Young New Member
    Dec 23, 2005
    This is my third post and from the response I have gotten, I guess I have an air leak on the suction line somewhwere. Once again, my pump struggles at kick on (30) to get going, bobbing back and forth from 25-30, A lot of cavitation at first while it struggles. Then after a long period of time it catches the water and shoots up to 50 (cut off), no problem at all once it gets going. Before this issue happened the cycle time was 2-3 minutes, its now up to 10 or more. Once it catches it you can hear a noticable difference in the sound of the pump. You then here it grab the water and take off. This can take quite some time though, like when you are manually priming the pump. My question is this. Its inch and a quarter black poly comming in. I think I am going to just scrap this line and trench in a brand new one. What kind/grade black poly do you recommend? Any other suggestions to what is causing this intial struggle to get going the pump has? Thanks...
Similar Threads: suction line
Pumps and Tanks Well Forum & Blog. Water is life. HELP - Air From Fixtures...Hole In Suction Line? Aug 7, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Suction line for 2" deep jet well May 27, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Priming point in suction line for shallow well? May 11, 2011
Pumps and Tanks Well Forum & Blog. Water is life. How to test for vacuum leaks on suction line? Nov 28, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Air Block in Suction line Sep 30, 2009
