Submersible pump stuck down a well
gbracht
Sudan
The problem: We have a Shurflo 12 v solar pump stuck inside the well casing, probably between 15 and 20 meters down. This happened while we were trying to install the pump.
There is about 20 meters of flexible hose attached to the pump, and the top of the hose is about 7 meters below the top of the casing (we can see it be reflecting sunlight down the hole, and dropped a rope to that level & measured). We can't see far enough to see where the flexible hose is bunching up.
The support rope broke, so there is nothing at the top of the casing that is connected to the pump.
Complicating factor: We are in the bush in Sudan, and have no access to experts or a hardware store. There are basic tools and random things like wire, rope, nails, barbed wire, etc. around.
What we need is a really clever way to grab onto that flexible hose...
Also, the casing constricts at about 25 meters down (2 meters below the current -end of rainy season -water level, but about 8 meters above the dry season static water level), so if we gave up and just tried to push the pump down, it would still get stuck above dry season static water level, rendering the well un-usable. It is both expensive and difficult to get a well drilled here, so we want to find *some* way to get this back to the top...
