Submersible pump starting to lift internal PVC casing after 140' of drop line has been pulled out
fishonzzz
Spokane washington
Hey All, I am new to well work and hit a snag. A little information on the well, I have no idea how deep it is. This is a pre-existing well on our property that has never been operational since we've been there. We have been able to pull 140 ft of galvanized drop line out, there was a check valve at the hundred foot mark. There is a PVC casing that starts about 4 ft down from the wellhead. Once I got the section out to put us at 140 ft shortly after we started cranking up the next section (coffin hoist) and the PVC casing started to rise with each crank. Lowered and re-raised The drop line trying a few inches to see if the pump would continue up smoothly and no go. Tips tricks and ideas would be awesome. TIA
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Possibly there is a ring of mineral deposits at the static water level that the pump is getting stuck on. If you can, devise a way to hold down or pound down the PVC liner to break through the mineral ring. Maybe dropping in some NuWell would dissolve it.
I have no experience. But I am thinking if you lower the pump, turn the drop pipe 180 degrees, and then lift, the pump might not snag when you then lift.
