stonedge
- Messages
- 2
- Reaction score
- 0
- Points
- 1
Had a dormant well for a few years after some wiring failed. I just finished pulling up the pump and inspecting everything. Found the control panel to be for a 3/4 so switched that out as the pump is only 1/2 hp. Wiring had been spliced in several areas and was cooked in one section so ran all new wiring. Tested the pump in a bucket and it worked great so dropped it back down the well. I shocked the well and ran a few regens on the water softener and the water was great. 5 days later I come home from work and go to the trailer to see if everything is holding, the gal that just moved in said that she had no water in the afternoon after using it some in the morning.
Sure enough, no pressure in the tank. I go to the well and I can hear the pump on. The ground is soggy but it had been raining so I wasn't sure if it was a breakage underground. I disconnected the line in the well casing, no water coming out.
I pulled the pump up the 100 ft again and tested it in a bucket. This time I have minimal flow, less than a garden hose from the 1-1/4" line, a far cry from 5 days before. I thought it might be the capacitor at the control panel so I swapped it out, thats not the issue (not sure if it even could be?)
So, before I go drop $650 on a new one, anything I should look into before hand? The pump is roughly 25 years old, can't read make or model, just a long number ending in 87 (year built?). Being that the trailer is rented out I'd rather not have any hassles but if it could be a relatively easy fix I'd rather try that first.
Thanks.
Thanks.
