sprinklers won't turn on
Discussion in 'Irrigation / Sprinkler Forum' started by Emily Verstraete, Jun 16, 2011.
  1. Emily Verstraete
    Emily Verstraete New Member
    Jun 16, 2011
    Kelowna, BC
    I tried to turn on my sprinklers yesterday after they have been dormant for the winter. Only one of the three stations will turn on. What could the problem be?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    One possibility is the common wire (usually white) is broken. That wire is linked from one valve to the next, usually connected with waterproof wire nut. If the connection is lost after the first valve in the chain, #1 would work but the follow valves would not. You didn't mention which valve in the chain comes on, so this is just a stab in the dark. Waterproof wire nuts can be purchased, but regular nuts with silicone packed will work just fine too.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Go to each valve and try to turn on manually, by slightly unscrewing the solenoid one turn or so. You may have to disassemble some valves, blow out the bleed ports, maybe replace some solenoids. And of course dont rule out wiring problems as mentioned by gary
  5. mike1059
    mike1059 irrigation tech.
    Jun 6, 2011
    irrigation tech. for a landscape company
    Portland, OR
    As gary said the most likely cause is a bad wire connection if station 1 comes on but 2 and 3 do not. If 2 or 3 comes on and the others do not check the flow control knobs in the center of the valves. Sometimes if the knob was turned partway down a slight change in pressure will keep them from opening.
  6. casey.robert.irving
    casey.robert.irving New Member
    Jun 21, 2011
    Atlanta, GA
    Agreed
    I agree 100% with both of them.
  7. Emily Verstraete
    Jun 16, 2011
    Kelowna, BC
    What if my station 2 turns on but not 1 or 3?
  8. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    I think Jimbo gave you very good advice by trying to operate the manually. did all 3 valve work when tried manually?
  9. mike1059
    Jun 6, 2011
    Portland, OR
    If all valves open manualy and all the valves are in the same valve box it is most likely the wire connections. If they are in differant boxes it could be a broken wire.
Similar Threads: sprinklers won't
Irrigation / Sprinkler Forum Sprinklers Won't Turn On Mar 1, 2008
Irrigation / Sprinkler Forum Manually opening the valves won't turn on sprinklers Aug 1, 2007
Irrigation / Sprinkler Forum Sprinklers worked, now not at all. For no apparent reason. Mar 11, 2017
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Feb 19, 2017
Irrigation / Sprinkler Forum Low Pressure Issue - sprinklers/well May 7, 2016
