Split heat pump comparisons
Discussion in 'HVAC Heating & Cooling' started by Cedrus, Aug 18, 2010.
  1. Cedrus
    Cedrus New Member
    Aug 14, 2010
    Our 17 y.o. York 3.5 ton is probably nearing its life span. We are having contractors from York, Goodman, Carrier and Trane come over and give us estimates for a replacement.
    Did a search on this site for heat pump comparisons and found nothing. Any recommendations?
    One thing came up: Our house is single level, 2200 s.f. and only one air return. 2 contractors wanted to install another air return and 2 said to take the existing 20x25 inch 3M filter out...and leave it open and install a four inch filter in the air handler, in the garage. Any thoughts on this?
    We understand that the most important thing is to have a KNOWLEDGEABLE/PROFESSIONAL/FACTORY AUTHORIZED installer do the job. Correct?
    Next most important is a FACTORY warranty or extended warranty. Ironclad, no tricky wording.
    Any comments or suggestions would be much appreciated.
Similar Threads: Split heat
HVAC Heating & Cooling Mitsubishi Mini split -should I worry more about enough heat or short cycling? Dec 6, 2013
HVAC Heating & Cooling LG Mini-Split Heatpump system - Operating temp? Dec 7, 2010
HVAC Heating & Cooling mini split heat/cool system Apr 18, 2010
HVAC Heating & Cooling Heatpump question - split system vs single Feb 21, 2010
HVAC Heating & Cooling How to split one heating zone to multiple heating zones? Sep 21, 2007
