Spin Closet Valve 45 Degrees
DaveC1
Oregon
My rough plumber installled a Closet Flange on a new sewer line that goes under a concrete floor(conversion of garage to bedroom). Subsequently we added tile and now the valve is approx. 1/2" low. I know I need to add spacers and I also want to change the direction the toilet faces by 45 degrees. Can I just drill some holes into the old closet Flange and tightly screw in the new, reoriented spacers?....thanks
WJcandee
Wise One
New York, NY
Closet bend? Flange?
We aren't fans of spacers, generally speaking, at least the ones that go on top of the flange. Just use two wax rings.
Your other question I will leave for others. However, as a practical matter, the waste should discharge vertically from the spigot of your toilet, so the direction you aim the bend isn't by itself an issue.
DaveC1
Oregon
Tks wjcandee....my issue with rotation is that the first flange is set and the position of the bolt supports won't allow a 45 degree rotation....I need something to attach to without breaking out the first flange....thanks, Dave
