Something leaking
Roger Bay
Florida
I wonder if anyone knows what the thing in the picture is. It is constantly dripping water out of the end of the white tube on the right. I thought it might be related to the irrigation system but since the pipe is going into the house maybe it's part of the potable water system. Would appreciate any help, thanks.
FullySprinklered
Georgia
It's a pressure relief valve. I've seen them locally, but have never actually installed one. I'm thinking technology has moved on from this device. Several methods of dealing with excessive water pressure downstream of a check-valve equipped water meter or PRV caused by thermal expansion have been tried. This was third runner-up. It's an Edsel.
Some people put those in as a secondary safety. Normally, it should not be opened up. Do you have a PRV in the house? If so, do you also have an expansion tank? One or the other (or both) of those may be failing, allowing the pressure to get higher, and causing that relief valve to open up.
IF you had a freeze, that valve may have been damaged. May not happen often in FL, but that could damage things including splitting the pipe in a worst case. Further north, the water would come in below the frost line to the house.
Check your water pressure...if it's high, the valve is doing its job.
