Soldered joint or thread on valve body?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by WorthFlorida, Jun 5, 2014.
  1. WorthFlorida
    WorthFlorida USCG escorting cruise ship leaving Port Everglades
    Oct 28, 2009
    Retired
    Orlando, Florida
    Hello all,
    I'm replacing a Price Pfister valve body (0x8-310A to a 0x8-340A) The new one has integrated valve stops. The replacement one has outside thread fittings with 1/2 inch inside fitting for soldering. The instructions do read that soldering is one way to connect the pipes after removing all plastic parts and cartridge. It's copper pipe all the way. My question for the pros is do you prefer to solder or use threaded female fittings to the valve body?
  2. jadnashua
    Solder it...cheaper, faster, more robust.
  4. hj
    Solder, no chance for a thread to leak.
  5. Sluggo
    Sluggo Member
    Mar 28, 2014
    Washington
    After you remove the internals, do the soldering with the valve body in a horizontal position to insure that you don't have any excess solder flow down internally where it might interfere, for example, with the service stops.
  6. WorthFlorida
    Oct 28, 2009
    Retired
    Orlando, Florida
    I completed the replacement of the valve body but two things to know,
    1) After removing the plastic parts and the cartridge, I removed the valve stops. There are what looks like neoprene o-rings and the valve stems are tip with the same material. The instructions did not mention the valve stops. Heat would have definitely melted these parts.
    2) A propane torch does not generate enough heat for the heavy brass valve body. A quick trip to the store for a MAPP gas unit took care of the problem.
Similar Threads: Soldered joint
Plumbing Forum, Professional & DIY Advice Need Opinion on a Soldered Joint Sep 6, 2014
Plumbing Forum, Professional & DIY Advice Failed Soldered Joint - Best Repair Method??? Aug 2, 2013
Plumbing Forum, Professional & DIY Advice Soldered Joint Faulire Rate? Dec 19, 2010
Plumbing Forum, Professional & DIY Advice copper soldered joint ? Jul 27, 2009
Plumbing Forum, Professional & DIY Advice pre soldered copper joints Jan 16, 2006
