solar heat for inground pool
Discussion in 'Solar and Geothermal Water Heating Forum' started by little buddy, Feb 25, 2009.
  1. little buddy
    little buddy New Member
    Oct 23, 2007
    Hey guys, I've been reading your different ideas for different situations. I was wondering if anyone had some good takes on how I could raise the temp. in my pool by about 10 or 12 degrees. Now I have to strugle to get 80 degrees and I do use a solar blanket. It's an 18' x 32' inground. My pump is located inside our house (laundry room). The roof over that area is about 12' wide and 20' from the bottom edge to the top. It does have a slight pitch. I was wonder about putting a couple of solar panels on the roof but I have very little knoledge in solar heating and the different valves that may be needed. Maybe someone could shed a little light on this.My 13 grandkids would love it. Pictures or drawings would be great. I failed to mentioned that I live in Ky.
  2. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Best bet is to search online
    There are companies that will design the whole system
    I've used a cheap system for a few years & it does raise the temp
    I'm not sure the cost on these
    But I'd check on what the company quotes you
    Then check to see if you can buy the parts for the same $$
  4. chris8796
    chris8796 New Member
    Jan 8, 2005
    Illinois
    Here is a bunch of useful info on the subject.
  5. little buddy
    Oct 23, 2007
    solar heat
    Thanks, a lot of good information
Similar Threads: solar heat
Solar and Geothermal Water Heating Forum How to disable my batch solar hot water heater temporarily Dec 8, 2016
Solar and Geothermal Water Heating Forum Plumbing Water Heater Into Solar Loop Sep 24, 2016
Solar and Geothermal Water Heating Forum Solar water heating optimization Jun 5, 2016
Solar and Geothermal Water Heating Forum Questions about solar heat Jun 4, 2015
Solar and Geothermal Water Heating Forum Summer Winter mode for Solar heat and Water. Aug 24, 2014
