Softener not softening?
Discussion in 'Water Softener Forum, Questions and Answers' started by 70runner, May 25, 2012.
  1. 70runner
    70runner New Member
    May 25, 2012
    Fallbrook, CA
    I installed a Fleck Twinpro 100 series (dual 8"x44" tanks) softener with brine tank about 4yrs ago. At the time I upgraded to 10% crosslinked resin to deal with the city water 1.5ppm free chlorine. My HM digital TDS meter says the city water is approx 440ppm and the softened water is about 300ppm. I checked the meter (don't have my calibration solution yet) against some bottled water, about 10ppm.
    Seems like I should be getting lower readings on the softened water, 50-100ppm. Is it time to change the media, brine tank issue?...suggestions?
  2. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    Your numbers ARE strange. It in the wrong direction. If your hard water has 400TDS then your softened water should have, say 480 or higher. Softeners add to those levels, not reduces them.
  4. ditttohead
    Jan 9, 2012
    Ontario California
    Twinpro 100... ugg, one of the less than stellar controls. It has been discontinued. Regardless, get a hardness test kit, a tds tester will do you no good. Order a hach 5B test kit.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I think your digital TDS meter has gone wonkey. I had one for awhile. finally bounced it off the basement wall. It didn't work any better after that either. LOL
  6. Gary Slusser
    Retired
    Now me, none of that emotional, probably from imbibing adult beverages the night before, violent stuff. I simply smiled wide as I gently laid mine in the trash one morning and wished it well in its next life.
  7. Tom Sawyer
    Nov 29, 2010
    Maine
    Yep. I don't know if anybody makes one that is worth the plastic but the few I have had and word from others pretty much says the same thing. Surprised someone hasn't come up with an app for the I pad that does it
  8. 70runner
    70runner New Member
    May 25, 2012
    Fallbrook, CA
    Appreciate the responses...
    Now that I look back on all the paperwork (memory not so good), I see that a softener doesn't necessarily change TDS, rather it exchanges magnesium and calcium ions with sodium or potassium ions (which of course most of you guys already know). The TwinFlo - dual tank approach seemed like a good idea at the time and is still going strong. Thx for the suggestion on the Hach test kit, looks like a good way to check softener effectiveness.
  9. ditttohead
    Jan 9, 2012
    Ontario California
    People complain about tds meters accuracy, than they complain that they cost more than 10 dollars. :) I sell tens of thousands annually, and yes, they are cheap, and yes they are junk, the price has dropped below the $10 price point. What do you want???
    BTW, I am smiling, total tounge in cheak on the thread. Honestly, I would recommend the HM digital series, these cost a few more dollars than the real cheap ones, and they can be calibrated and they actually work and are accurate. A good old fashioned analog meter (Myron L model 532T1 is over $300) is a little tought to justify when a HM digital TDS-4 is only $30.
  10. 70runner
    70runner New Member
    May 25, 2012
    Fallbrook, CA
    Ditto, noticed your Riverside location...anyone around here sell the Hach5B over the counter?
  11. 70runner
    70runner New Member
    May 25, 2012
    Fallbrook, CA
    Hach test results: supply water, 9GPG; softened water immediately turned blue with first drop. Digging back in my records I found the lab test I did prior to sizing/installing the softener. It showed CaCO3 hardness at 180ppm which would seem to be consistent with the Hach reading. Bottom line, appears the softener is doing ok.
  12. Tom Sawyer
    Nov 29, 2010
    Maine
    Very good. Thanks for the update
  13. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    I am having a hard time understanding why Gary Slusser needs to make rude personal remarks about other members. I don't think personal attacks help anyone.
  14. F6Hawk
    F6Hawk New Member
    Mar 20, 2012
    Flyer
    Alaska
    Some things are beyond comprehension, you must simply accept that they "are".
Similar Threads: Softener softening
Water Softener Forum, Questions and Answers New GE water softener not softening, the GPH meter is going full cycle in seconds Sep 24, 2012
Water Softener Forum, Questions and Answers 1950-60 era Peerless softener has quit softening Mar 11, 2010
Water Softener Forum, Questions and Answers I need a softener help me pick Yesterday at 6:52 AM
Water Softener Forum, Questions and Answers New Softener Questions Mar 23, 2017
Water Softener Forum, Questions and Answers Question about new softener and Drain Install Mar 14, 2017
