New softener is all setup and running, with many thanks to you folks here! I followed the initial setup instructions, and have it in service.
I set it to regen on the first night, and noticed a bunch of resin was discharged from the drain when I walked by it the next morning... I call manufacturer, and they suggested I check the integrity of the 1/4" PE line to the brine tank, thinking it may be sucking air. I manually commanded the softener to fill the brine tank and held up the float valve to fully pressurize this line, and can't see any leaks under positive pressure. Not sure how to check under vacuum.
Another thought was the softener may have been over-filled with resin. To check this, I set it to regen again on night #2. Same thing this morning...
Everything appears to be working correctly, so I'm a bit stumped. My system is fairly simple, and I am 99.9% sure it is all installed correctly. Softener is an Avid IX-1054. 1.5 ft capacity. If you're standing in front of the panel, the water enters on the right side, and exits on the left. That is the way the arrows lay it out, as well as the manual.
Below is the order that I have it assembled:
Well>check valve>pressure switch>50 micron sediment strainer>tee with one outlet feeding pressure tank>softener>Big Blue with 25/5 DGD>house piping.
Any thoughts? Hoping to get this figured out before all of my resin wanders into my yard. Lost about a shovel full so far.
Thanks,
Chad
Thanks,
Chad
