diggity
Sorry for the long post here, but I have to get this off my chest, and maybe this will be a breadcrumb trail for anyone else with horrible problems with iron in water like we have. Some of you have been kind enough to offer me some really good advice on some of my previous posts, and for that I am grateful. I have definitely learned some things about my water, but unfortunately, despite all the money spent and time and mental energy put into it over the past few months, I have to admit that our water is really no better than when I started.
To recap, we have over 20 ppm of iron, TDS well over 1000, pH around 5.25, and 50 grains of hardness. Our big softener system did a reasonable job of cleaning it up over the past decade, but we've always had iron breakthrough and staining. So a few months ago I went on a crusade to fix it once and for all.
Step 1: Rebed our old calcite filter with new calcite. This did virtually nothing to raise the pH.
Step 2: Install soda ash injection system. This did indeed raise the pH, and seemed to improve overall water quality (taste, odor), but we still got iron breakthrough.
Step 3: Install Katalox Light system in front of softener. I also installed a spigot just before the softener, to monitor the quality of the water as it goes into the softener. My goal all along has been to get the iron down to zero or near zero BEFORE it gets to the softener, so as to prolong the life of the softener and its media. Unfortunately, it quickly became evident that the 2 cuft KL system was not up to the task, as monitoring revealed there was still a huge amount of iron hitting the softener. There was also apparently some sort of other oxidized mineral (manganese?) coming out of the KL, because the water was green. Green when you first pour it out, then orange if it sat in a bucket for an hour. Horrible stuff to be sending on to my poor old softener.
Step 4: Install peroxide injection system. So at this point we're injecting both soda ash and peroxide with 2 Stenner pumps as soon as it enters the home. Then contact tank and on to the KL and eventually the softener. Unfortunately, this did not help at all... all it did was oxidize more ferrous iron to ferric, such that the water going into the softener was now orange as soon as it was poured.
Step 5: Install Catalytic Carbon filter to remove oxidized iron. Let's just say this was my mistake. Catalytic carbon is not a good media for removing sediment.
Step 6: Rebed carbon filter with Chemsorb media. OK, now we're getting somewhere. The Chemsorb does a much better job of removing oxidized iron. However, there is STILL a substantial amount of iron going into the softener. If I fill a bucket it will be slightly orange, and darker orange a few hours later.
Step 7: Adjust feed rates of soda ash and peroxide. Strangely enough, it seems like the soda ash is counter productive at this point, so I have turned that Stenner pump off at the moment. With it on, the water going into the softener looked even worse. I have no idea why, because I had thought that raising the pH was an important pre-treatment before any kind of oxidizing filter. So this makes no sense. I have cranked up the peroxide injector so that I am now using about a gallon of 7% peroxide per week, which seems like a lot to me. Injecting this much peroxide seems to help, but it is not helping enough, because there is STILL iron going into the softener.
Meanwhile, months have now elapsed and I shudder to think what all this experimentation with the incoming water has done to the softener. :-(
Every morning I fill a bucket of water for the chickens. This has been a good opportunity to monitor water quality, as I've been giving them the water from the monitoring spigot described above... chickens don't care about iron. So I get to observe changes in water quality at the same time every day. A few days ago, I decided to do a little experiment. I filled a 35 gallon trash can with raw water (no treatment of any kind). I had an old 1 cuft tank and flow-through head laying around which I could use as a crude filter. I also had an old fish pond pump lying around, so I had the makings of a very primitive water treatment system. The media I used is literally sand and dirt which I scraped up from the driveway. I swept and shoveled up about a half cu.ft. of it and dumped it in the old tank. Managed to find the appropriate fittings and hooked it up to the fish pond pump. Now you'd have to see the water in the 35 gallon trash can - I should have taken a picture. Although it comes out of the well crystal clear, after sitting overnight, it is absolutely horrific. It is the color of chocolate milk with big particles of rust and Heaven knows what else floating around. But guess what... after it goes through my hillbilly driveway sand filter, it looks really good! When I first turned the pump on and started using the filter, it blew chunks for a while, and I had to do a manual "backwash" by swapping the hoses around and dumping out the soupy effluent. But after that it settled down and it does a surprisingly good job filtering out the rust. I took a sample this morning and tested the water. Although it looks crystal clear, the total iron is still at 3 or 4 ppm - I assume this is from very fine rust particles that the driveway sand can't remove (because, let's face it... it is driveway sand!). Remember, this is down from 20+ppm in the raw water. pH actually came up a little, going from 5.25 to around 6. I assume this is because the water now has some CO2 in it, so there might be a little bit of carbonate buffering going on? And the TDS went down... The TDS from my hillbilly treatment system is about 1150, whereas the TDS coming from my main household treatment system... the one I have spent so much time and money on... is 1300. So at this point, by some measures, the chickens are now drinking better water than I am! (we actually have an RO at the sink, so not really, but you get my point)
So where on Earth does this leave me? A few observations:
1) I have to give my old softener credit, because, while it never removed 100% of the iron, it did in fact remove MOST of it. Which is a Herculean feat, as I have found out. I imagine it did so well because the incoming water was so low in pH and because all the incoming iron was ferrous.
2) My water apparently wants to be surface water. There seems to be no substitute for good old air when it comes to oxidizing. At the rate that we're currently using peroxide, I'll be spending $40 per month on peroxide. Air is free. And if my guess is right, exposure to air also helps moderate the pH somewhat via carbonate buffering.
So I'm thinking maybe my next step is to do one (or both) of the following:
1) Re-plumb the system so that the softener is FIRST, not last. I know this goes against conventional wisdom, which says that you should put iron treatment before softening. But that just doesn't seem to work with extreme water like ours. If the softener can remove, say, 80% of the iron through ion exchange, then I'm happy to let it do so. Maybe putting the KL system after the softener will remove whatever is left.
2) Install an atmospheric storage tank. I've been Googling around and it seems there are a few different ways to do this, so if anybody has experience with atmospheric storage tanks, I'm all ears. The goal would be to not flood the basement. I could put a high volume aquarium pump in the tank to make sure that plenty of air gets circulated. And the Grundfos MQ pumps look like a decent option for re-pressurization.
We have thought many times about drilling a new well, but we just can't afford it, especially when success is not guaranteed. Our neighbors all have better water than ours, but none of them have perfect water. Everyone has a softener at minimum and everyone gets at least a little bit of iron staining. Ours is the worst, by far, but nobody has perfect water, so even if we did drill a new well and the water was somewhat better, we'd still probably need some form of treatment.
<sigh> What to do, what to do?
Anyway, sorry for the extremely long post. I just had to vent.
