I have a new home that is approx 2 years old. The home has a septic system. Whenever it rains we get sewer gas in the house. I have found a toilet drain line with a drilled hole in it as well as three connections in the vent lines that were simply dry fitted togethr (No cement). All have been corrected and we are still experiencing the problem. I have replaced the wax ring on all toilets. All toilets, sinks, showers, etc are used on a regular basis (dailey) so no dry traps (theoretically).
Based on past experience I assume there are additional joints in the vent lines that have not been cemented together. I have read in a couple places that they can cap the vent lines and introduce smoke into the sytem to locate leaks. My questions is how well does this work if the leak is inside finished walls? How do you find the smoke?
Thanks for your help.
