Slow tub drain.
Discussion in 'Shower & Bathtub Forum & Blog' started by ario, Dec 12, 2005.
  1. ario
    ario New Member
    Sep 29, 2004
    I ran the shower on the first floor for the first time and noticed the drain was slow. A typical length shower would result in 4-6 inches of water. I used three bottles of Drano foaming cleanser and that helped quite a bit. Now I get about 2 inches of water. I tried snaking it, but the hard right angle of the tub drain doesn't allow me enough leverage to push it in. I was going to try an acid based cleaner next but was worried about the possible effect on 80 old plumbing. The initial drain and overflow tube for the tub are bronze and the trap is galvanized that goes into cast iron. Any ideas?
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    clog
    I would never use Draino or any other thing that pours down the drain.
    Did you remove the lever plate on over-flow and pull the lever linkage out to gain access to clean?
    If it's 80 years old, you may still have an old cast iron p-trap in the basement or crawl space. There should be a 11/2" brass plug on it as a clean out.
  4. ario
    ario New Member
    Sep 29, 2004
    I had the same trouble snaking through the overflow. The trap is all galvanized with a galv. plug as a cleanout...rusted solid.
    Why wouldn't you use chemical cleaners?
  5. Cass
    Cass Plumber
    Nov 12, 2005
    Go to lowes and buy a small 15' snake in a drum with a turn handle. Then remove the trip plate and snake down to the trap and as far as you can go. If it is 80 year old galv. drain you won't be taking any clean out cover off unless a miracle occurs or it has been removed on a regular basis. You may not be able to get beyond the trap. I use lye on occasion and under certain circumstances but I have a specific way of using it. It works every time.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The reasons drain cleaning chemicals are not recommended include the fact that they will not open are truely clogged drain and the chemicals create a hazzard for anyone working on the drain. I would venture a guess that you drain is only 1-1/2", and in something as old as you have, maybe even 1-/1/4". The small drain size will of course clogged easier than a 2". There may be an elbow that is not a wide radius and that would make snaking difficult. I would suggest that the best thing to do is to call in a professional plumber. Do tell him what chemicals you used, when you used them, and how much you used.
  7. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    I never use caustic chemicals such as Drano, but I have successfully used enzyme-based drain cleaners for years, such as DrainCare.
    An enzyme-based drain cleaner will not harm the tub/shower or the drain, or anyone working on it, but it will dissolve hair, soap scum, grease, and other organic gunk to clear sluggish drains.
    You simply run warm water in the drain and pour in the enzyme-based drain cleaner, allow it to eat overnight, and then flush it down with very hot water. I start with a kettle of boiling water.
    If it's really sluggish, you may have to use more than one treatment, but it WILL work.
    Mike
Similar Threads: Slow drain
Shower & Bathtub Forum & Blog Shower drain is slow Nov 1, 2014
Shower & Bathtub Forum & Blog The downside to slow draining showers Aug 20, 2014
Shower & Bathtub Forum & Blog Slow draining bathtub Dec 12, 2013
Shower & Bathtub Forum & Blog Standing Water, Slow Drain in new tub install Apr 14, 2012
Shower & Bathtub Forum & Blog New Tub Drains Slowly Sep 17, 2011
