SLow Faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BrianL, Dec 11, 2008.
  1. BrianL
    BrianL New Member
    Mar 11, 2005
    Raleigh, NC
    Hello All,
    I have a 2 year old Kohler single-control kitchen sink faucet (model number K-10412).
    For the last few months the pressure has been falling, both the cold and hot water equally. The hand sprayer is still OK. Removing the aerator has no effect. I took the body apart today and could not find anything amis. No debris or problems found.
    Is the valve going bad somehow? Replace it and see what happens?
    THanks for your thoughts!
    --Brian
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Take a look at this linked parts diagram for your faucet.
    Kokler K-10412 parts diagram
    I believe the problem is going to be in the #75878 / DIVERTER ASSEMBLY
    Call 1-800-4-Kohler to get your warrantee parts.
    Simply removing it skould improve the faucet immediately but when you use the side spray water will come out of both the side spray and the faucet spout so side spray flow will be somewhat diminished...
  4. BrianL
    BrianL New Member
    Mar 11, 2005
    Raleigh, NC
    Holy Smokes ...
    ... Batman, that was fast!
    That makes sense, I will call tomorrow!
    Thanks a ton,
    --Brian
  5. BrianL
    BrianL New Member
    Mar 11, 2005
    Raleigh, NC
    Got it
    OK, got the part (Kohler sent a new valve and o-rings as well). I have the diagram of the faucet, but cant figure out where the actual diverter goes. Do I take apart the base of the faucet (ie - completely remove the faucet and take it apart), or is there someway to get at it from below the valve.
    --Brian
  6. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Most single handle faucets after you remove the center cartridge take the spout firmly by the hand wiggle back and forth lifting at the same time
    this should pull up and off the diverter will be in the center column of the faucet,
    you should have plumbers stem grease or vaseline to rub around the o rings
    and other moving parts as you put back together
  7. Redwood
    Dec 15, 2007
    Service Plumber
    Yup thats what you have to do.
    Take it apart from the top down and lift the spout off.
  8. BrianL
    BrianL New Member
    Mar 11, 2005
    Raleigh, NC
    Awesome, thanks guys, worked like a charm!
    --Brian
Similar Threads: SLow Faucet
Plumbing Forum, Professional & DIY Advice DIal-Ese Shower Faucet Slowly Closing Itself Apr 12, 2016
Plumbing Forum, Professional & DIY Advice shower faucet slowing the water flow (w video) Sep 11, 2011
Plumbing Forum, Professional & DIY Advice Slow running moen single handle Kitchen faucet Aug 21, 2011
Plumbing Forum, Professional & DIY Advice Lav faucet slow to shut off... Jul 15, 2010
Plumbing Forum, Professional & DIY Advice Kitchen faucet hot line slow after water shutoff Jun 8, 2010
