Slow cycling of well pump / pressure tank
Desmo
Catskills NY
Hi all,
We have a pressure tank setup with a well. The system cycles between 20# and 40#. I just noticed the system is cycling slowly with no fixtures "on" (maybe 10-15 minutes from high to low).
I'm guessing the water is being pumped backed into the well. Do I need a check valve? The pump is a bit of a mystery to me, but it's a pounded well about 70' deep.
Can I install a check valve in the house where the water line enters?
Thanks much in advance for any information!
- Mark
jimtum
AAW
Decatur Tx
If you don't see a check valve above ground then you may either have a hole in the pipe or the check valve, foot falve is not holding and as ballvalve said you will need to fix it from the bottom up
