Dale Johnson
Appreciate your time in advance:
Situation: My plumbing IQ is low, live in Cleveland in a large 97 year old house, yesterday morning a water main break hit our area - 24 hours later and it's not fixed, yesterday temperatures quickly elevated above freezing thawing several inches of snow/ice, mid afternoon yesterday the water meter (internal) was running so hard/loud that I heard it from the kitchen (one floor up), yesterday in the basement I found 'leakage' coming from the base of two of the four exterior basement walls...
Actions taken: I immediately turned off the water. This morning around 3am the leakage had retreated mostly, the flow indicator on the meter was still immediately upon shut off and now, I turned on the water and the intensity of the incoming water was identical to how I noticed it from the floor above the day prior. I let it run while monitoring the two leakage areas. Once it filled the tank (water main still not fixed), the leakage had regained it's initial extent and the intensity of the incoming water had backed off.
At this time, the water is turned off, the water main not yet fixed, and the leakage from both walls is how I found it. I've read a bunch of information online with varying opinions.
What say you all? Any insight is most welcome.
