sinkmaster removal
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lncohan, Sep 17, 2005.
  1. lncohan
    lncohan New Member
    Sep 14, 2005
    Recently, I replaced my kitchen faucet successfully but found leakage in the pipes underneath the sink. I replaced all of them with PVC and found out that the disposal was leaking. Since it is an old Sinkmaster, I decided to replace it with a new Insinkerator Badger 5+ but found out that the collars are totally different. How do I remove the old Sinkmaster, it seems to be turning with the collar. Pictures would be appreciated if possible.
  2. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Sometimes you need to take a hacksaw and cut off the 'nut' on the bottom under the sink. Hold it at a shallow angle and try not to cut any part of the sink. Once the nut is opened, pry it off and then the drain should come out of the sink.
    OR Buy the same brand as the one removing and reuse it.
    Hope this helps.
    Jason
  4. Kristi
    Kristi Tradesman Plumber
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    you can buy one of those cheap HD wrenches that give you a big grab on those kind of nuts (lol) - I hold on to the threaded part and wrench the nut off. And don't forget, there's a spring loaded split ring that's holding the nut on that the phyical garburator is spun onto! you need to pry that puppy off with a flathead and it will come apart easily from there... watch your eyes and your hands, when you're putting the new split ring on with the Badger 5 as well as taking off the old...
  5. lncohan
    lncohan New Member
    Sep 14, 2005
    removing sinkmaster
    I'm not sure I explained myself well. I am trying to remove the disposal itself. Once that is off, I think I can do the rest. Thanks for the responses so far.
  6. ge01734
    ge01734 New Member
    Jan 27, 2008
    replace Sinkmaster 450 Disposer
    I too ran into the same problem. The chopping blades broke off and the disposal is rusted out. I tried to remove the disposal, but it just turns on the base. Did you ever get it removed?
    Thanks,
    Don
  7. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    You need to hold the disposer and turn the big fat nut to the left. Disposers are made to turn easy so you can line up the pipes and/or discharge line. Getting the new one is a real challenge if you have never done one before.
Similar Threads: sinkmaster removal
Plumbing Forum, Professional & DIY Advice Sinkmaster Jul 6, 2009
Plumbing Forum, Professional & DIY Advice Sinkmaster 450... Nov 18, 2007
Plumbing Forum, Professional & DIY Advice Sinkmaster 450 Dec 20, 2004
Plumbing Forum, Professional & DIY Advice Faucet Handle Removal & Leak Repair Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet removal. Can't get nut off. Feb 2, 2017
