Hot Water Shower Stem
Andrew1969
Florida
I recently replaced a water shower stem and I can not get the water to totally turn off. The stem is for an old Danco Sterling faucet. I am pretty certain I have the correct stem and it was installed correctly. I realize the stems will wear out quickly if continuously over tightened, however, since it is new I don't believe that is the case. I am definitely not a plumber, but never had any issue like this in the past replacing sink and shower faucets. Any help or suggestions would be appreciated.
John Gayewski
Iowa
You either have the wrong stem or a washer also needs replaced. Possibly the body needs cleaned and your shredding rings or washers. I'm not sure what your working on but something ain't right.
