single pole double circuit breaker
Discussion in 'Electrical Forum discussion & Blog' started by nelsonba, Dec 1, 2007.
  1. nelsonba
    nelsonba Member
    Sep 28, 2005
    Are these legal under NEC?
  2. BrianJohn
    BrianJohn DIY Senior Member
    Jun 22, 2007
    Does it have a UL or equivalent seal/sticker, if so yes.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    It appears that you are talking about what is often called a "Tandem" breaker that connects to one side of the load center, and contains two separate circuit breaker devices with two handles.
    The only risk would be if someone incorrectly connected both hot wires of what was intended to be a multiwire branch circuit, with only one neutral, to both terminals of a tandem breaker.
  5. Igor
    Igor New Member
    Dec 2, 2007
    Former Motorhome Electrician
    See for UL's position on the use of tandem breakers.
    The 42-circuit limit, which dates back to the 1930's when flammable rubber-insulated wire was used, is going to be removed in the 2008 edition of the NEC.
Similar Threads: single pole
Electrical Forum discussion & Blog How To Wire Single Pole Light Switch with Pilot Light Dec 11, 2014
Electrical Forum discussion & Blog Can I use 2 single pole 30 amp pushmatic breakers as a double pole set up May 28, 2014
Electrical Forum discussion & Blog Double Pole Single Throw Switch Jun 4, 2012
Electrical Forum discussion & Blog Can I use a (mistakenly purchased) 3-way switch as a single pole switch? May 21, 2012
Electrical Forum discussion & Blog triplex breaker 20/20/20 single 2 pole 20a, dual COMMON TRIP 1 pole 20a? Feb 27, 2012
