masterprocrastinator
Hello, I am a homeowner who knows nearly nothing about plumbing. I have 2 sillcocks (didn't know that term before researching the issue) that leak when turned on - no leak when off. I'm not at home at the moment but I believe the leak is from the handle as when I have a hose attached & the water on, water drips down the hose. I don't know the brand of faucet/sillcock & I cannot remember if it has a vacuum thing on top (assume frost-free, don't know); the house is approx. 20 years old. I have tightened the packing nut in the past which helped temporarily but it appears as though I need to replace the packing nut washer or possibly the washer at the end of the stem. I have found guides on how to do that but I keep reading allusions to: "stem may be soldered on", "get out my torch", etc. I have no torch nor soldering equipment at hand & am terrified if I remove the sillcock I will break something & be unable to turn water back on in the house (wife & children need sinks, toilets) or worse, cause an interior leak, until it is fixed.
After that ramble, my question is this: After removing handle & packing nut, how do I know if the sillcock is threaded in or soldered on? Should the stem unscrew or just slide out? Give the stem a gentle counter-clockwise turn & if it doesn't move stop & call a professional?
I am ignorant of 95% of the terms you experts are using here when addressing other's leaky sillcock questions, so please spell it out (I thank you dearly in advance). However, I am a quick learner & have a toolbox full of the basics (including teflon tape).
