Shower/Tub temperature
Discussion in 'Shower & Bathtub Forum & Blog' started by ascii12, Mar 15, 2005.
  1. ascii12
    ascii12 New Member
    Mar 15, 2005
    The temperature setting on our gas water heater (brand new) is set to medium-high. The water temperature in all the sinks is very hot, as we like it. However, the temp in the shower in the master bath and in the tub in the guest bath is just warm. I see no obvious adjustment on the tub or shower handles to change the temperature. There is no logo on the handles. They are single handles that turn thru 270 degrees to adjust flow and temp. Any help would be appreciated.
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    Have you removed the handle and looked to see if there was any adjustments under it?
  4. jadnashua
    Some of the single handle rotating valves have a limit adjustment to prevent people from accidentially setting it too high. As noted, check to see if yours does.
  5. ascii12
    ascii12 New Member
    Mar 15, 2005
    There's a set screw holding the handle in place and a single screw at about the 1 o'clock position that looks like it holds on the face plate. Should I remove both of those?
  6. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    Anyway to post a picture of this valve? Would like to see what your working with.
  7. ascii12
    ascii12 New Member
    Mar 15, 2005
    My wife looked at it and found the Moen logo. (I missed it. Typical male) I will take a picture of it and post it tonight.
  8. ascii12
    ascii12 New Member
    Mar 15, 2005
    Here's a picture of the fixture.
  9. ascii12
    ascii12 New Member
    Mar 15, 2005
  10. jimbo
    jimbo Plumber
  11. ascii12
    ascii12 New Member
    Mar 15, 2005
    Thanks for the help. I'll give the adjustment a try if I can decipher all the plumberese.
Similar Threads: Shower/Tub temperature
Shower & Bathtub Forum & Blog Sterling ensemble curve shower/tub surround Oct 5, 2016
Shower & Bathtub Forum & Blog Recommendations for new shower/tub hardware............ May 31, 2016
Shower & Bathtub Forum & Blog Single handle shower/tub valve recommendations for good flow rate? Jan 30, 2016
Shower & Bathtub Forum & Blog Three Handle Diverter - Changing Shower/Tub Diverter Turn Direction Dec 26, 2015
Shower & Bathtub Forum & Blog Bleach/chlorine smell in new shower/tub only (not in the rest of the house) Oct 13, 2015
