Shower/Tub Fixture Help
Discussion in 'Shower & Bathtub Forum & Blog' started by SheilaG, Aug 28, 2008.
  1. SheilaG
    SheilaG New Member
    Aug 28, 2008
    We’re getting ready to remodel our bathroom ourselves (complete demo) and would like to change the tub/shower configuration and need a little help. Currently our shower fixture and tub fixture work independently of each other so there is no divert. There is a showerhead with a single handle, and then the standard 3-piece tub fixture with a spout and 2 handles, 5 pieces in all. We’d like to change to a 3-piece shower fixture (head, handle w/divert, spout) and want to know if this can be easily done. Thanks.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Well it depends...
    Is this one of the old tubs where the spout comes out through a hole on the side of the tub?
  4. SheilaG
    SheilaG New Member
    Aug 28, 2008
    No...the spout comes out of the wall above the tub.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    It shouldn't be a problem. You will need the tile wall redone but as far as the plumbing goes not a problem.
  6. SheilaG
    SheilaG New Member
    Aug 28, 2008
    Since we're ripping the old tile out that won't be a problem. Thanks for your quick responses.
  7. jadnashua
    Code today requires the shower to have antiscald technology. There are two approved methods of doing this: pressure balanced and thermostatically controlled. Some may combine both. Thermostatically controlled is more expensive, but, I like it better. You can set one temperature winter/summer, first shower or last one in a series, and until you run out of hot water, the temperature will remain the same and you never have to touch that knob/lever or however that model controls the temp. Another advantage for some is that it provides you with a flow control. The single handle pressure balanced valves typically do not have a volume control - it is either fully off or fully on.
Similar Threads: Shower/Tub Fixture
Shower & Bathtub Forum & Blog Looking for high flow shower/tub fixture Feb 6, 2015
Shower & Bathtub Forum & Blog What do I need...Plumbing fixtures for shower/tub Oct 10, 2013
Shower & Bathtub Forum & Blog Sterling ensemble curve shower/tub surround Oct 5, 2016
Shower & Bathtub Forum & Blog Recommendations for new shower/tub hardware............ May 31, 2016
Shower & Bathtub Forum & Blog Single handle shower/tub valve recommendations for good flow rate? Jan 30, 2016
