Enosez
Just bought a house that has a EJM shower pan installed.
No leaks but the problem is that when you stand in it or move around it squeaks and makes all sort of noise.
My solution was to spray expanding foam (minimal) under the pan. I can get to three of the sides of the pan but not the face of the pan.
I thought this would help but I found that the reinforcement ribbing under the pan runs in both directions. So basically I will only be spraying around the outer edge and not the the inner edge closest to the drain (where I believe the problem is).
I was going to use a crowbar to lift the pan slightly and see if I can get the spray foam nozzle under the ribbing or even drill a small hole in the ribbing that I can see and get to. The problem there is that the ribbing runs so that I cant get to all of it.
What would you do in this situation? Spray the foam where I can or does anyone have a better idea?
