Shower - drain smell and stain
Discussion in 'Shower & Bathtub Forum & Blog' started by sarahbell, Nov 22, 2008.
  1. sarahbell
    sarahbell New Member
    Nov 22, 2008
    Hello,
    I'm having a problem that I don't understand. I'm in a small apartment building (4 units) and recently my bathtub drain has started smelling bad, sewer gas I assume. It seems to happen after I run water in the sink briefly (not so much if I let it run for a minute or more) but it also happens at random times because I go in the bathroom and it sometimes just smells. I do occasionally get a blocked drain (I have long hair) but it's flowing fine now and draino always seems to fix it.
    There are two other weird things happening. One is that the toilet and kitchen sink drain both randomly bubble, and sometimes that smells but not usually. It never overflows, just bubbles loudly. The other thing is that I keep getting brown stains on the tub from the overflow (I think that's what it's called, the thing that has the lever for the tub drain), like some fine brown mist is being forced out of it. The stains rinse away when I shower but they are resistant to being wiped with a cloth, they need a lot of water to go away. They keep appearing more frequently, maybe once every other day, as does the smell - every day.
    Any ideas as to what is causing the smell and stains? This is actually and old house that was made into apartments and I have a feeling corners were cut here and there. I think I smelled the same smell, faintly, in the laundry room which is on the wall opposite of my bathroom.
    Thank you!
    Sarah
Similar Threads: Shower drain
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Wednesday at 2:58 PM
Shower & Bathtub Forum & Blog Odd Shower Drain Rough In Mar 5, 2017
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Feb 25, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
