Shower drain problem
Discussion in 'Shower & Bathtub Forum & Blog' started by helena, Sep 15, 2010.
  1. helena
    helena New Member
    Sep 15, 2010
    Canada
    Hi!
    This is a last ditch attempt before I just give up and yank the entire stall out... I noticed water pooling around the basement stall after taking showers. I looked at the drain and noticed the flange was cracked. I've removed it but now cannot find a suitable replacement part. It looks like a standard 2" ABS pipe, but the problem is with the threads. The female threaded part is still there and fine, so my understanding is that I only have to replace the gaskets and fit a new top part (with the grid part). Problem is, none of the male parts have the proper threads for the female part. They lock on but ''skip'' and pop out as I try to screw it in. This shower was put in about 25 years ago. The stall is in great shape and we just remodeled the entire bathroom, so I'd hate to replace it now. There is no floor or back access unless I take out the stall. Thanks for any insight.
Similar Threads: Shower drain
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Wednesday at 2:58 PM
Shower & Bathtub Forum & Blog Odd Shower Drain Rough In Mar 5, 2017
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Feb 25, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
