shower drain & p trap code question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nc8861, Jul 19, 2008.
  1. nc8861
    nc8861 New Member
    Jun 25, 2008
    North Carolina
    Watching some TLC tonight on some home improvement show and this guy says that according to code, compression fittings on a shower p trap can't be used in an area where you can't get to - the example on the show was a second floor bathroom between floor joists. Is this true? Does everything have to be glue joints?
    I'm in a 30 yr old house, 2nd floor bathroom - only access from 1st floor would be through the kitchen ceiling.
  2. jimbo
    jimbo Plumber
    Compression fittings on tub drains have been around since long before glues pipe. I have heard that some local codes don't allow them, but in general I think you can still use them.
  4. hj
    joints
    Usually the prohibition is about what kind of compression joints you use.
  5. nc8861
    nc8861 New Member
    Jun 25, 2008
    North Carolina
  6. hj
    trap
    The compression part is the inlet. The large nut is a ground joint. But regardless, I would NEVER use that trap in a concealed location. I have seen too many of them with snapped locknuts at the ground joint.
  7. nc8861
    nc8861 New Member
    Jun 25, 2008
    North Carolina
    That's enough evidence for me - I'll take it back. Thanks for your help.
Similar Threads: shower drain
Plumbing Forum, Professional & DIY Advice Sewage ejector air coming up shower drain Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Shower tray drain isn't centered Dec 4, 2016
Plumbing Forum, Professional & DIY Advice Setting drain fit tile shower Nov 30, 2016
Plumbing Forum, Professional & DIY Advice Replacing shower drain but it it too high Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Moving Shower Drain Rough Stub Nov 20, 2016
