Shower Arm Diverter - Pressure issue?
Discussion in 'Shower & Bathtub Forum & Blog' started by pmetiv, Aug 9, 2009.
  1. pmetiv
    pmetiv New Member
    Oct 17, 2008
    New York, NY
    I want to install a diverter at the shower arm to use a handshower.
    I have been looking for a while and found brands like Hansgrohe and Danze who sell them for $30 to $50 :(. While at HD today I saw a Danco for $15 :).
    When looking at it closer, only a small water access is open...probably 3/4 of the 1/2in opening is blocked :confused:.
    Won't this kill the water pressure? Are the other brands like that too? Unfortunately this is the only brand I can find in a store and would have to order the other brands online...want to know if someone owns a brand with a full 1/2in opening. Is the big price only because of the brand or do they let more water out?!
    (Hope this makes sense...I should have taken a picture!!)
    Thanks for your help.
    Pierre
  2. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Welcome to the world of federal law/regulation. The shower must not pass more than 2.2 gpm at 80 psi (IIRC). To ensure they meet the standard, flow is restricted as you have observed. Many products use a removable washer to limit the flow in the US, but allow for easy removal outside the US. Some US residents even take advantage of this to readily break the law. Other flagrant lawbreakers have been known to drill out these restricted orifices.
  4. jadnashua
    It takes a bit of engineering to take that restricted flow and make the shower head produce a pleasing result. Removing the restrictor in them may turn them into a fire hose, but, you'll quickly run out of hot water, too. Not always, but you tend to get what you pay for...
  5. pmetiv
    pmetiv New Member
    Oct 17, 2008
    New York, NY
    I understand the regulation and already have it on my showerhead and handshower. But why does it need to be on the diverter too?! So far I only saw the Danco but this is molded in brass. There's no way to remove it like you would with a plastic piece. I guess I need to test it but wouldn't the flow be even worst now that the diverter is also restricted on top of the showerhead?
    Pierre
  6. hj
    diverter
    If the flow is restricted to the proper amount at the diverter, then the head's restrictor would allow the full flow since there would not be any excess for it to control.
  7. pmetiv
    pmetiv New Member
    Oct 17, 2008
    New York, NY
    Makes sense. I guess I need to test it now.
Similar Threads: Shower Diverter
Shower & Bathtub Forum & Blog Shower Diverter Help Tuesday at 11:00 AM
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Feb 27, 2017
Shower & Bathtub Forum & Blog help finding shower head diverter Jan 28, 2017
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Piping and a 3 way diverter in shower Nov 15, 2016
