should new caulk peel off easily??
Discussion in 'Shower & Bathtub Forum & Blog' started by dl21, Jul 8, 2012.
  1. dl21
    dl21 New Member
    Jul 5, 2012
    seattle
    Hi,
    I asked my first question on on this forum july 5th about my new shower caulking job (see July 5th, "will caulk cure?").I thought maybe I would be OK, but the issue now is that I am able to easily just peel off the new caulk, (there is grout under it).
    Should I be able to peel it off like that? I still have not used the shower, and am wondering if maybe the surface was not cleaned before the contractor used the latasil, I believe, caulk. I understand using alcohol is a good way to clean the surface after the old caulk is removed. I know the contractor removed the old caulk, but I did not see him use any alcohol or anything to clean after getting rid of old caulking.
    Do I need to remove recently applied caulk, prep surface with alcohol and re caulk? Thanks so much!!
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Is the tile sealed? Was it sealed earlier?
    Are you using Silicone or LAtex Chaulk?
    JW
  4. dl21
    dl21 New Member
    Jul 5, 2012
    seattle
    Thanks for your response. It was not sealed. The previous caulk was latex.
  5. dl21
    dl21 New Member
    Jul 5, 2012
    seattle
    and the current caulk is silicone. (Latasil)
  6. jimbo
    jimbo Plumber
    San Diego, CA
    No it should not peel off. Getting a bad tube of caulk is a lot more common than you would think. If the caulk is exposed to >100º , or freezing, during transport or storage, it may very well fail. Does it feel like it cured, but is just no sticking?
  7. dl21
    dl21 New Member
    Jul 5, 2012
    seattle
    yes. it feels and looks cured, but I can easily, very easily pull it right off. (There was a peice that was sticking up and I pulled it just to see what would happen) Thanks. Sounds like I should recaulk?
Similar Threads: should caulk
Shower & Bathtub Forum & Blog Should I caulk the back of a shower valve escutcheon? Jan 31, 2010
Shower & Bathtub Forum & Blog Bathtub Mortar - Should I be worried? Feb 13, 2017
Shower & Bathtub Forum & Blog Should I DIY a Shower Pan and Tile? Jan 27, 2017
Shower & Bathtub Forum & Blog Should I reuse my old Moentrol valve? Jul 1, 2016
Shower & Bathtub Forum & Blog What kind of paint/primer should I use in a shower/bath room? Nov 12, 2014
