I know exactly what you mean when you stated "square cut" grey slip joint tubing washers. Home Depot includes them with each piece of thin walled brass tubing you purchase. Sometimes they work and occasionally they refuse to seal properly which is why as a homeowners I stock a few of every variety. You might try using the "beveled" pliable variety which HD also stocks in plastic bags. Sealing issues can also be from the cheapo zinc coated slip joint nuts which I detest. eBay is my best friend when it comes to stocking up on these type consumables. I especially like the real chrome plated solid brass slip joint nuts (both 1-1/4 inch and 1-1/2 inch sizes). You do have to purchase quantity lots of 25/bag which seems a lot however you will be amazed over the course of 10 years how many you use for both sink and flushometer repairs. In answer to your ask check out link below...you will have to purchase in quantities to make it worth having to pay for shipping and minimum lot sizes....
http://www.hodesco.com/default.aspx?page=item detail&itemcode=50-509
Thanks, SWong, for your insights.
I just found out that I can edit both title and content on a discussion thread. I hope my edited title will result in more good advice from this remarkable community.
I'm ready to give up on the zinc 1-1/4" slip joint nuts and replace them with quality 1-1/4" chrome brass nuts. I realize I can buy them in bulk from Hodes after registering and pretending to be a professional plumber. Are there no other sources?
I've attached an image of what is currently installed and still leaking. It is 17G chrome on brass and it was installed in 2010 when we remodeled and installed the sink and cabinet holding it. The inset shows the plastic parts used by the general contractor's project supervisor to install the sink in 2010.
On 12/31/19, as I attempted to reassemble the joints with the green (labeled for plastic only washers) from HD. I noticed that the tailpiece coming down from the popup on the sink was ~1/8" too long. It caused a gap between the tailpiece to the drain connection and the trap. I said, "aha, this caused the leak." I grasped the sink tailpiece firmly and unscrewed it. I noticed that it had torn threads, so I documented that with photos and removed the popup from the sink. Sure enough, there was brass from the tailpiece in the first few threads. I dug that out and squared up the threaded end of the tailpiece and screwed it back in using PTFE tape. It was no longer too long. I took the time to lube the threads on the zinc nuts with some lithium grease that somehow escaped the first hazardous waste purge in preparation for our move. They screwed on and off smoothly. I reattached the p-trap using the new green washers from HD again and tightened the nuts just slightly beyond hand tight. The outflow end of the p-trap leaked slowly. I tightened the nuts a bit more with a Crescent wrench and it still leaked. Am I correct in understanding that too tight is as bad as not tight enough?
How should I best use my rapidly evaporating time to set things right? I can't find brass nuts to replace the zinc ones locally. I couldn't find decent replacement p-trap this week. Perhaps CalSteam in Redwood City (the biggest local plumbing supply house) will have a new stock of p-traps sometime later this month. They are out of stock now. The local big box stores have 22G cheapo wonders with zinc nuts.
What are reliable brands for a 17G p-trap assembly I could try to source elsewhere locally once business starts in earnest again next week? Many of our reliable supply houses have closed recently.
Are there other possibilities I've failed to consider that might work better?
FWIW, I inquired at the desk of our major supplier if I could purchase a threaded tube like the popup tailpiece and was told I needed to buy a popup assembly. I found that in the downloadable Hodesco catalog Tubular section that they can supply a 12" 17G chrome/brass tube (threaded both ends) that is probably what I thought I wanted (Item # 51-276, 1-1/4" x 12," Chrome 17 Ga., $12.55.) Perhaps others also sell these. I don't have the time to search, but I thought I should share what I discovered.
Thanks,
John
