Shallow well pump will not hold pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by zanderd, May 28, 2013.
  1. zanderd
    zanderd New Member
    May 28, 2013
    Maintenance at ice factory
    Indiana
    hello, i recently installed a Coleman 3/4 HP Shallow Well Jet Pump that i bought at Menard's. that sits in a pump house in my yard. it is used for watering flowers etc. it is a hard plumed setup with a check valve on the suction line, no pressure tank. The discharge line has a T on it with a ball valve on top for priming and a ball valve on the discharge line, The pump has been working great for two weeks, last night i was having trouble with it short cycling, adjusted the switch didn't help tried a new 30/50 pressure switch didn't help. i have replaced the check valve and checked the suction line, pump seals, and discharge line for leaks, none found. The pumping level is also good with clean water all the time. so i put a pressure gauge on it and plugged the pressure switch port, the pump it able to produce 70 psi all day, but when the it is unplugged it drops down to zero psi this is why it short cycles. i have been searching the internet all day and cannot figure out were the pressure is going when it is shut-off. when their are no leaks a new check valve and the discharge tube is closed with a ball valve. the pump only has 5 hours on it
    thank you for your help
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    It won't hold pressure without a pressure tank.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    I agree you need a pressure tank. What you're trying to do is to compress a liquid. Can't be done.
    John
  5. zanderd
    zanderd New Member
    May 28, 2013
    Indiana
    thank you for your help, their must have been a air pocket under the ball valve/priming port previously because it seemed to cut in and out just fine until i bled the air pocket out, i just need it to cut out when the spray nozzle is closed. do you think i could use a accumulator tank because don't have allot of room to spare and it is only going to be used for lawn care.
Similar Threads: Shallow pump
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Feb 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump installation Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow Well Jet Pump Recommendations? Jan 4, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Filter before shallow well pump? Dec 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump w/ 1"intake May 23, 2016
