OBXpumper
I hand drilled a well (2 in, galvanized steel with a 4ft stainless well point) 24ft, about 2 years ago. The well then sat for that time while I saved up for the rest of the project. I then hooked up a utilitec 1hp irrigation jet pump. I first used 1 1/2 in intake pipe. I have 3 zones pumping 4 heads each. This is the outer banks and we have nothing but sand.
The Problem: I have it run through a timer and a relay (both orbit). Everything cuts on fine. When I prime it, it isn't loosing any water. When I cut it on, the water from the check valve (at top of well) to the pump flows to the heads. Then the water stalls at the top of the pump. The pressure rises slowly to 10 then 15. Then suddenly it has 30-40 psi and runs like a champ, for 5 seconds. Then it stalls again, well running and water gurgleing at top of pump intake pipes. this goes on every 5 minutes like clockwork.
The water level is 6ft under the ground surface, leaving approx. 18 ft of filled well pipe. I have the intake pipe all the way to 22 feet, leaving 2ft at the bottom. I have flushed the system several times with house hose, replaced all intake piping, including downsizing to 1 1/4 in intake pipes. I have checked for air leaks. I am at a loss. All that I can think is my intake pipe is too long for the pump. But it is only really having to lift 6 ft to surface. Is my well shot?
