Sewer smell confined to inside of toilet bowl
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jim165, Dec 14, 2006.
  1. Jim165
    Jim165 New Member
    Dec 14, 2006
    Guys, just did a search and didn't find quite the exact same situation I'm experiencing. I get a urine/ sewer smell when I flush my rarely used 2nd bathroom toilet. However the smell is coming directly from INSIDE the bowl...not the tank, not the base where the wax ring is, nor from the sink or tub drains. Occasionally, my master bathroom toilet has the same problem. The smell does not permeate the entire house, it's restricted to the toilet bowl and, at it's worst will smell up the bathroom. I've scrubbed the entire toilet with bleach and hot water, yet the smell persists. I keep the toilets spotless at all times, so it's not a cleanliness issue.
    Just a litte more info:
    House is on concrete slab
    Toilets do not rock, they are sturdily mounted
    There is carpet in both bathrooms (yuck)
    House is 8 years old.
    seemingly no drainage problems, but I've just used the super-concentrated drain cleaner last night in case there are clogs in the system. I will check back today to see if there is a difference.
    Otherwise, what else could be the problem? I'd really appreciate any insight!
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Try adding about a 1/4 cup of bleach to the tank full of water, stir / mix it well and flush the toilet 1 time and let it sit for an hour then flush a few more times to rinse out the tank better.
    See if that helps any.
    How do you know the wax ring is not bad?
  4. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    My first suspicion is to question the toilets being vented properly...sewer gas coming back into toilet.....?????
  5. Jim165
    Jim165 New Member
    Dec 14, 2006
    I'm not definite that the wax ring is not bad, but if it was, I thought maybe i'd be able to smell some of the fumes at the base of the toilet. When I put my head directly into the bowl while flushing, I could distinctly determine that the smell is coming from the commode's drain (I thought it was the water at first).
    It seems to intensify just before the bowl begins to fill back up. No smell from any other drains in the bathroom nor the base of the commode..
  6. Jim165
    Jim165 New Member
    Dec 14, 2006
    Randy,
    What am i looking for in terms of venting tubes, hoses, etc.? The only feed I see going to the toilet is the cold water supply line...Thanks...
  7. Jim165
    Jim165 New Member
    Dec 14, 2006
    Thanks for the suggestion, Cass
    I acutally tried this after I scrubbed the tank walls and bowl with bleach. I then filled the tank with boiling water to flush the entire system. After refilling the tank with cold water, I inserted a chlorine tablet. This has masked the smell a little bit, but the smell's still there...
  8. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    I don't think your nose is as accurate as you think it is.
    Do what Cass suggests and if the odor persists, re-set the toilet.
  9. Cass
    Cass Plumber
    Nov 12, 2005
    The chlorine tablets don't do what a 1/4 cup of bleach in the tank will do.
Similar Threads: Sewer smell
Plumbing Forum, Professional & DIY Advice Sewer smell in apartment, HELP :( Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Sewer smell Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Sewer gas smell in toilet bowl Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Sewer Smell coming from pipes connected to hot water heater Nov 19, 2016
Plumbing Forum, Professional & DIY Advice Multiple types of sewer smells? Jun 28, 2016
