Sewer Repair (pics) in progress
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Lakee911, Feb 27, 2008.
  1. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Hey All,
    I thought that I would share some pictures of my sewer repair in progress. These couple of fellas hand dug the 7feet down to the pipe where I have an offset joint that is causing problems.
    http://i159.photobucket.com/albums/t131/lakee911/P2270017.jpg
    http://i159.photobucket.com/albums/t131/lakee911/P2270018.jpg
    http://i159.photobucket.com/albums/t131/lakee911/P2270021.jpg
    They think they'll have to dig back on the pipe and raise it up, or maybe use an 11 degree angle. Personally I think they should cut the cast back 6 or 8" on either side and use PVC between the two with a couple of Ferncos or No- Hubs. I know it's tough to see what's going on down there.
    I'm going to talk to them again in the morning.
    Jason
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Fun time of year to be doing that.Remember it well and that was 20 yrs ago.:eek:
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  5. Lakee911
    Aug 23, 2005
    Columbus, OH
    Yes, I know that they have some violations there. Shh...
    Jason
  6. hj
    pipe
    I see snow and guys working but nothing about the pipe. If it needs a fitting, and they might be looking a long time for a 1/32 bend, then two Ferncos and a longer section of pipe is not going to replace it.
  7. Lakee911
    Aug 23, 2005
    Columbus, OH
    I don't follow what you're saying, hj.
  8. Lakee911
    Aug 23, 2005
    Columbus, OH
  9. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    That looks like a 22&1/2 degree bend. thats not going to be easy.
  10. Lakee911
    Aug 23, 2005
    Columbus, OH
    Good thing I'm not doing it then, huh? :) I think this guy would rather work harder than smarter so he's not willing to bring in the backhoe.
    Jason
  11. Lakee911
    Aug 23, 2005
    Columbus, OH
    Those fellas just got done fillin' in the hole as I was on my way home. I would have liked to inspect the repair before they closed it up.
    They did no compaction of any fill, nor did they backfill with sand or gravel around the pipe. There is so much dirt, I'm having to haul some of it away. They said they packed it in and around the pipe and it will not be settling. It's under warranty if I have a problem though, they say.
    So, anyhow ... how can I speed this settling process? I was thinking of using something that's for watering the roots of trees so I can esentially fill the hole with water deep down and help it settle? What do you think?
    Thx,
    Jason
  12. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    I think it will settle.
    I think they should send a camera down the drain. That way you can atleast see the handy work they did. Have them make you a tape or dvd of it also.
  13. Redwood
    Dec 15, 2007
    Service Plumber
    I too would wonder what they did. You definitely want the camera to take a look. Compaction is not an issue unless they dug deeper than the pipe. As for the extra dirt mound it on top it will settle. If you haul it away you will end up with a depression.
    BTW here a mini excavator rents for about $450 a day.
  14. Cass
    Cass Plumber
    Nov 12, 2005
    I would not haul away any dirt.
    It came out it, will go back. You can move it around back of the house then as it settles you can add it back in to the trench.
  15. hj
    why?
    IF that is what they need, then they should use it.
    This implies that you want them to not use a fitting and bend it in the couplings. Twisting or bending couplings is not a substitute for a fitting.
    But in any case, if there was some indecision as to how to do it, I would have wanted to see it done, before covering it to be sure it was done correctly, and not just cobbled together.
  16. Lakee911
    Aug 23, 2005
    Columbus, OH
    Well, at the first sight of problem, they will be back to send a camera down the line to view the pipe. It does have a warranty too. As sketchy as the guy is, he has always pulled through (although a little late sometimes) in the end.
    They cut back more than what was shown in the last picture. They used PVC and a 22.5 degree angle w/ fernco couplings to connect to the existing pipe. Before they dug the hole and cut the pipe, it wasn't obvious how much, if any, angle there was between the two pipes.
    I'm only 26 and I've done more contractor supervision (both at work and at home) than I think average person has. I own my house and I've done framing, drywall, plumbing, roofing, electrical work, tile, finishing, painting, appliance installs, toilet installs, cabinetry, concrete, etc, etc. Everything I do I am constantly learning how to do it better. Every job that I have contracted out, I end up learning something too and I have fewer and fewer problems with each one. So, the thing to learn here is that I should have inspected the final repair before back filling.
    The hole is maybe 4ft x 4ft and it's piled up 12in, at least, above the hole and 12in above the hole next to it in a 3ft x 4ft area plus they stashed about three wheelbarrow loads in the back. I estimate that I have 50-60% compaction.
    I know it will settle, but short of removing it and compacting it, can I speed it up any? I was thinking of filling the hole with water, but if I did that would the loose clay just turn in to quicksand, so to speak? Is that ok to do in this cold weather?
    Thanks
  17. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    backfill
    we used to backfill with water all the time.It does speed the porcess along.
    Just let your hose run in the hole at a slow stream when it start to settle
    add more soil.Keep your caution tape around it.
    Clay
  18. Lakee911
    Aug 23, 2005
    Columbus, OH
    Ok. I'll wait until Monday to start that. It's going to be too cold until then. It's snowing now.
    Jason
Similar Threads: Sewer Repair
Plumbing Forum, Professional & DIY Advice Concrete sewer line repair advice Jul 27, 2015
Plumbing Forum, Professional & DIY Advice Repair of partially collapsed sewer main drain Apr 30, 2015
Plumbing Forum, Professional & DIY Advice Sewer line repair or replace? Oct 22, 2010
Plumbing Forum, Professional & DIY Advice Trenchless Sewer Repair, Good or Bad? Dec 9, 2008
Plumbing Forum, Professional & DIY Advice Repairing sewer line at cleanout Aug 27, 2008
